Forums >> Revit Building >> Technical Support >> wall disappears when placing window!!!
Mon, Jun 18, 2012 at 2:45:53 PM | wall disappears when placing window!!!
ivanzep
HELP!...I'm trying to place a window (80x30cms) on a wall, but when i do the wall disappears leaving only doors and windows visible on this wall!! this only happens on my door/window floor plan. I've tried a few things:
  • checked my plan region and it seems fine, since other included walls are behaving normally.
  • I've also applied a different view template from another plan but did not work.
  • this wall has split-faces but deleting them makes no difference.
  • Only when I make the window bigger, the wall reappears. but that's no good since i need a smaller window :/
I've attached a screen capture to illustrate this issue...has anyone come across issue????
Mon, Jun 18, 2012 at 2:47:18 PM | wall disappears when placing window!!!
Maybe a corruption issue / many be a video card issue.  Duplicate the view and see if it is all there.
Mon, Jun 18, 2012 at 2:54:19 PM | wall disappears when placing window!!!
ivanzep
WWhub, i've tried duplicating it but nothing changes. every other plan is displaing this wall normally except for this particular floor plan...
Mon, Jun 18, 2012 at 2:55:54 PM | wall disappears when placing window!!!
ivanzep
changed graphics settings...no luck.
Mon, Jun 18, 2012 at 3:08:56 PM | wall disappears when placing window!!!
OK... Now create a new plan - not duplicating.  GOTO View Tab / Plan Views - uncheck the "do not duplicate" box and create a new floor plan for that level.
Mon, Jun 18, 2012 at 3:15:05 PM | wall disappears when placing window!!!
ivanzep
YEP THAT WORKS, GUESS I'LL HAVE TO REDO THIS FLOOR PLAN. GOOD THING ITS NOT COMPLEX. YOU THINK ITS A BUG?
Mon, Jun 18, 2012 at 4:07:41 PM | wall disappears when placing window!!!
You don't have to redo anything.  Window the entire plan and use your filter to remove all model elements from the selection set, then copy to clipboard and paste same place in your new plan - done.
I think you changed something in your old plan.  Probably hid that wall.
Mon, Jun 18, 2012 at 4:17:43 PM | wall disappears when placing window!!!
ivanzep
I'LL TRY TO THINK OF THAT NEXT TIME, ALREADY REDID EVERYTHING  :D. I'LL STILL TRY YOUR METHOD THOUGH JUST FOR CONFIRMATION PURPOSES. THANX
Fri, Sep 14, 2012 at 6:43:39 AM | wall disappears when placing window!!!
matthewh75
3 Stars: 3 Votes
Just use 'cut' & 'paste aligned to same place' on the window - this normally sorts this issue out for me
Wall disappears when plan region applied -RAC 2008
Mon, Aug 27, 2007 at 2:23:25 PM
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:20 AM
Cornice on exterior wall disappears when I place window 2' above it?!
Mon, Nov 28, 2011 at 2:22:07 PM
Placing doors/windows at midpoints of walls??
Tue, Jan 25, 2005 at 5:44:52 PM
Window disappearing with changed sill height
Fri, Dec 15, 2017 at 3:03:24 PM
Page generation time: 3.5468
