14 Users Online (12 Members):
Forums >> Revit Systems >> Technical Support >> Wiki Help absolutely worthless
Trying to remember something I used to know and can't remember: How to do 2 different materials in a vertical wall stucture. Something with split region and assigning layers, can't figure it out, go to wiki only to get run around in circles. Does anyone know the name of the moron who set up the wiki site???
http://www.turbosquid.com/Search/Artists/Revitaoist |
Go to MODIFY>SPLIT SURFACE then you can PAINT the wall with the material you want.
Case in point, went to AUGI and found the answer in 3 minuites: http://forums.augi.com/showthread.php?111811-Multiple-wall-materials&highlight=vertical+wall+materials
Thanks teafoe, but I was wanting to do it in the vertical wall structure
We don't use the wiki help. When you install, you also install the built-in help. It is much better and you can set your pointers to it instead of wiki.
Hub, how do I set it to go to the built in help as default when i hit the "?"
To reset the Help pointer, I wrote this for 2011.. 2012 is different and I have not rewritten it yet
In your Revit.ini file set this:
UseHelpServer=0
HelpBrowser=0
You also need to set the locally installed help such as: ENUHelp.cab=C:\Program Files\Autodesk\Revit Architecture 2011\Program\
What file type can Revit write to that will create a non editable 3d image |
Wed, Sep 5, 2012 at 2:59:25 PM
Typical Details |
Mon, Mar 26, 2012 at 10:53:44 AM
3D Studio Max imported into Revit? |
Fri, Jun 29, 2012 at 5:42:25 PM
Revit MEP pipe diameter difference |
Thu, Feb 9, 2012 at 11:01:35 AM
Setting up ODBC Export with Open Office Base |
Tue, Mar 8, 2011 at 5:32:11 PM
