Forums >> Revit Building >> Technical Support >> how to do a tubolar spiral?
Mon, Jun 18, 2012 at 11:30:18 AM | how to do a tubolar spiral?
querosaber
how to do a tobular spiral?
Mon, Jun 18, 2012 at 11:38:14 AM | how to do a tubolar spiral?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What Revit version are you using?
Here is one for 2012 http://www.youtube.com/watch?v=aXtY0ngSIto
Mon, Jun 18, 2012 at 1:07:34 PM | how to do a tubolar spiral?
Thread Post Kudo! Thread Post Kudo! #3
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
My advice is to use a swept blend.  Start with one swept blend, which has an arc for a path, and a square for the first profile.  Give it a second square profile, elevated as high as your spiral will rise in a half turn.
finish the swept blend--then mirror it, move it end to end, and start copying the segments upward.  Perhaps this meets your needs right here.
But, for added fun, you can use the edges of this swept blend as the 3D path of a regular sweep, since sweeps are much more flexible for profile changes.
Edit:   And of course, any of these profiles could be hollow/a tube instead.
Edited on: Mon, Jun 18, 2012 at 1:10:47 PM
Tue, Jun 19, 2012 at 8:11:22 AM | how to do a tubolar spiral?
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Here's an article that I wrote recently about how to do the helix in multiple loops, controlled by parameters:
http://planta1.com/forum/entry.php?17-How-to-create-a-parametric-helix-with-multiple-loops
Planta1 Revit Online Consulting | info@planta1.com
Residential Spiral Stair
Mon, Feb 16, 2015 at 10:02:06 AM
Help - curtain wall on spiral ellipse
Mon, Oct 11, 2010 at 6:02:04 PM
Spiral Extrusions
Mon, Feb 1, 2010 at 5:40:22 PM
Beam attached to s spiral slab
Sun, May 26, 2013 at 7:07:46 PM
spiral stair needed, please.
Thu, Jul 5, 2007 at 5:38:38 PM
Page generation time: 0.9247
