8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Differing Coordinate Systems
27 Posts No Rating |
I am trying to import a revit model into a new project so that I can make a site plan in a seperate file, but I need tyo use shared coordinates and I keep getting the error message (see attached).
Does anyone know a way to sort this out?
Thanks very much in advance,
Kieran
Obviously, the twor revit files do not have the same coordinates and you have to reset one. From your HELP:
Acquire Coordinates
When you acquire coordinates from a linked Revit project, the shared coordinates of the linked project become the shared coordinates of the host project, based on the position of the linked project instance in the host project. There is no change to the host project's internal coordinates. The host project also acquires True North from the linked project. The origin of the linked project's shared coordinates becomes the origin of the host project's shared coordinates.
To acquire coordinates:
- Click Manage tab Project Location panel Coordinates drop-down (Acquire Coordinates).
- Place the cursor on a linked model instance, and click.
The host model file now has the same shared coordinates as the linked model file. If other loaded linked models share coordinates with the host model, they also acquire the new coordinates.
Dealing with plumbing systems |
Fri, Aug 31, 2012 at 5:27:33 PM
Family with coordinate parameter? - Revit 2010 |
Wed, May 12, 2010 at 3:45:58 AM
11
Locating a Coordinate... |
Thu, Apr 21, 2016 at 10:45:21 AM
Why Coordinate System of the input dwg not retained ? |
Mon, Jun 29, 2009 at 8:16:05 AM
revit 2017 Wrong acquired coordinates, not share same coordinate system |
Tue, Jun 26, 2018 at 7:37:57 AM
