21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> View Range or Cut Plane Settings for Split level and Cape style
6 Posts No Rating |
What are the best view range (cut plane) settings when doing a cape style plan (upper level) and split level plans? I am working on projects for both style homes. On the split level my problem is I can see the windows on the lower level but not the upper level in plan view. Cape style homes the floor plan is not coming out nice when I try to add dormers. I appreciate any tips.
Thanks!
You will most likely have to use "Plan Region" to get the look that you are looking for.
Thank you! The "plan region" works great for this. I appreciate it.
View Range Cut Plane Associated Level is wrong |
Fri, May 4, 2012 at 11:46:09 AM
view range not right |
Thu, Mar 4, 2010 at 1:08:41 PM
View range queations |
Mon, Jan 18, 2010 at 4:48:17 PM
View Range |
Fri, Mar 13, 2009 at 5:05:41 AM
split level homes |
Tue, Feb 17, 2004 at 7:04:24 AM
