Forums >> Revit Building >> Technical Support >> 3D Acad model to toposurface
Fri, Jun 15, 2012 at 2:38:12 AM | 3D Acad model to toposurface
shenlunglinnk
3 Stars: 2 Votes
Hi
I imported a  acad 3d terrain model to Revit first, and then tried to "make surfaces" on it
However when I used toposurface / create from import, everything became gray, and I couldn't select my imported 3d terrain.
How can I make my terrain look like an "object", not only lines in different heights?
Thank you
Fri, Jun 15, 2012 at 6:29:51 AM | 3D Acad model to toposurface
Start by thoroughly reading your help file - main heading: Toposurfaces / Create from Import
Toposurface and ACAD files
Tue, Nov 2, 2004 at 4:26:49 PM
toposurface
Fri, Sep 8, 2006 at 5:40:55 AM
Toposurface from Autocad File
Mon, Oct 6, 2008 at 4:06:02 PM
Issue with linking ACAD file
Fri, May 21, 2010 at 1:05:43 PM
CREATING A TOPOSURFACE EASILY
Sun, Aug 27, 2006 at 3:03:53 AM
Page generation time: 0.5649
