Forums >> Revit Building >> Technical Support >> How to extend top flange of beam (over top of column)?
Thu, Jun 14, 2012 at 4:07:35 PM | How to extend top flange of beam (over top of column)?
KseniaEic
I am trying to model an angled column extending to the underside of the top flange of a beam. When I extend the column to try to "Cope"the beam, Revit automatically cuts the beam back (behind the column). How do I get the column to be attached to the bottom fo the top flange of the beam?
Thanks
Fri, Jun 15, 2012 at 10:35:08 AM | How to extend top flange of beam (over top of column)?
KseniaEic
Just to clarify, I want the beam to be behind the column except for the top flange (to extend over the top of the column and cap it off)
How do you align top of beam with top of column?
Wed, Feb 11, 2009 at 8:19:29 AM
Aligning top of column to top of beams that are set out by bottom of steel
Thu, Dec 12, 2013 at 12:35:41 PM
slope top of column
Tue, Jan 19, 2010 at 2:59:05 PM
Beams over Supports
Thu, Jun 28, 2007 at 2:47:33 AM
Structural Beam Visibility
Tue, Feb 27, 2007 at 11:37:36 AM
Page generation time: 4.9353
