Forums >> Revit Building >> Technical Support >> In-Place Mass + add profile = (NO ARC's please)
Thu, Jun 14, 2012 at 6:41:07 AM | In-Place Mass + add profile = (No curves please)
zuzullo
How can I edit a point of a profile and have only straight lines?
See pic bellow:
http://content.screencast.com/users/zuzullo/folders/Jing/media/7eaed7ce-5fbb-4cf4-8f62-f378affae64d/2012-06-14_0931.pnghttp://content.screencast.com/users/zuzullo/folders/Jing/media/7eaed7ce-5fbb-4cf4-8f62-f378affae64d/2012-06-14_0931.png
Edited on: Thu, Jun 14, 2012 at 6:42:32 AM
Do you wanna SKYPE Revit? Its quicker Smile
Thu, Jun 14, 2012 at 9:21:00 AM | In-Place Mass + add profile = (NO ARC's please)
4 Stars: 205 Votes
Select the curve then click on "Add Edge", now select the points to create a straight edge instead of a curve
107641_ScreenHunter01_Jun._14_15.16.jpg107641_ScreenHunter02_Jun._14_15.16.jpg107641_ScreenHunter03_Jun._14_15.18.jpg
Mon, Jun 18, 2012 at 2:35:14 AM | In-Place Mass + add profile = (No curves please)
zuzullo
ok, what am I doing wrong?
Made a 60sec video if you dont mind checking my process Smile
VIDEO LINK: http://screencast.com/t/WdYqeqbcA5
Thanks!
Mon, Jun 18, 2012 at 3:40:58 AM | In-Place Mass + add profile = (NO ARC's please)
zuzullo
Oh, is it because you are working in Vasari? I hope that is not an issue Smile
Edited on: Mon, Jun 18, 2012 at 3:41:39 AM
Mon, Jun 18, 2012 at 6:16:17 AM | In-Place Mass + add profile = (NO ARC's please)
4 Stars: 205 Votes
I can't see your video... firewall but it's the same process in Vasari or Revit, Select the curve then click on "Add Edge", now select one point then the other. done.
Mon, Jun 18, 2012 at 7:59:12 AM | In-Place Mass + add profile = (NO ARC's please)
zuzullo
I know it should work. We have a support contract that is also trying to find out the issue.
Do you know is this process is compatible with all kinds of "forms generators"?
Mine was generated through here: (hope you can see pictures then) and then I used 2 profiles and connect then to create a solid.
http://content.screencast.com/users/zuzullo/folders/Jing/media/e2f69cdf-4734-49b6-9d6a-9411853f28bd/2012-06-18_1438.png
Mon, Jun 18, 2012 at 12:59:56 PM | In-Place Mass + add profile = (NO ARC's please)
4 Stars: 205 Votes
Wierd, don't work in mass, only vasari... Whatever... just dissolve the mass and create again with 3 profiles. Done
Tue, Jun 19, 2012 at 3:40:12 AM | In-Place Mass + add profile = (NO ARC's please)
zuzullo
When I disolv and connect the 3 profiles I get curves again! Sad
We are running revit 2012, can this have been fixed on 2013?
Tue, Jun 19, 2012 at 4:32:08 AM | In-Place Mass + add profile = (NO ARC's please)
4 Stars: 205 Votes
Dissolve then select the bottom and the middle profile and create mass, now select the middle and the top profile and you will have the final mass.
Tue, Jun 19, 2012 at 6:28:03 AM | In-Place Mass + add profile = (NO ARC's please)
zuzullo
Thanks. Ok, this is going, slow but going...
You deserve to have the file for your help! Feel free to check it out!
Next challenge is:
http://content.screencast.com/users/zuzullo/folders/Jing/media/08cda0d8-fb71-4d11-a3cb-7d0a6b8887d1/2012-06-19_1307.png
I tried to use your "Dissolve" tecnique and then offset the profiles. But the profiles are 3D and the offset tool is 2D only Sad
Do you have any ideas on this?
Tue, Jun 19, 2012 at 9:20:46 AM | In-Place Mass + add profile = (NO ARC's please)
#11
zuzullo
OK I got it.
OFFSETs for mullions and curtain systems are under control!
Now, how can we FILLET all the intersections:
http://content.screencast.com/users/zuzullo/folders/Jing/media/65151932-1540-4c15-a2e3-f416e80f6634/2012-06-19_1616.png
Tue, Jun 19, 2012 at 1:31:29 PM | In-Place Mass + add profile = (NO ARC's please)
#12
4 Stars: 205 Votes
You can't use the Trim tool for that, don't work like that, stretch your mass to the face of your building then select the curtain system and click on "Update to face".
Watch the video: http://screencast.com/t/PGuXYQVKN
Wed, Jun 20, 2012 at 2:11:49 AM | In-Place Mass + add profile = (No curves please)
#13
zuzullo
I got the exact same strugle as you when trying to transform a curve to a sharp edge. Our support team could not find a straight forward solutiion either. It looks like a bug.
But further on, how do you manage to stretch all the mass, to a precise offset, all around?
Even the normal offset of the curtain elements does not offset in the right direction! So I cannot use those points as temporary support for the offset. Recalculating the position of all points, (so that all surfaces are flat), will take a whole day. Please tell you you have a plan Smile
Check screen shot bellow:
http://screencast.com/t/I30a06MML
http://content.screencast.com/users/zuzullo/folders/Jing/media/8ab1736b-df4d-4bbe-a119-907700c31e9f/2012-06-20_0904.png
Edited on: Wed, Jun 20, 2012 at 2:17:44 AM
Sweeping Solid In-Place Mass
Tue, Apr 27, 2010 at 3:30:38 AM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 7:05:36 AM
Attatching an image to a 'Model in Place' mass
Fri, Apr 27, 2012 at 9:36:34 AM
Arc Walls with curved top?
Thu, Aug 7, 2008 at 2:04:21 PM
Page generation time: 0.9407
