21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Apply material to object style not working.
Hi,
In Revit 2013 i have an issue when i go to objectstyles / select a style to apply a material / select a material in the
material library / click ok,
and the material doenst apply itself to the object style,
Is this just with me or is it a rac 2013 problem?
any solutions?
Kind regards,
D.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Have you tried changing the material of the actual object in its properties?
I agree. I seldom use an Object Style to control a material (although you can and it depends on the 'Catergory').
Manage the material at the element / family level. Changing the material of the object style changes the material of all elements of that 'Category' which is not usually a good thing.
The OS assigned material only affects families without assigned materials, it's basically just there to assign a default material for a category. If there is a material assigned inside the family, that's what will be used.
TKennedy is correct and that is what i am using it for.
so anyone else have trouble applying materials in objectstyles?
peace is the path."
Mahatma Gandhi.
Dafpfy,
I don't usual change the defaults so I tried this in 13 on a default wall and did not have a problem. Perhaps what you are trying to change is in a different category or defined differently in the family.
BTW
I don't know why AutoDESK had to screw around with this process. They sure made the material library harder to use. Those darn AutoCAD programmers again!
Object Style not showing unless object highlighted |
Thu, Jun 8, 2017 at 3:29:24 AM
Material schedule not picking up materials in railing object |
Fri, May 6, 2011 at 4:03:35 PM
Sketchup to Revit - Layer/Material Problems [ 1 2 ] |
Thu, Jun 10, 2010 at 11:04:46 AM
23
Object Styles |
Thu, Oct 4, 2007 at 10:42:57 AM
Object Material Not Showing |
Wed, Dec 9, 2015 at 9:05:15 AM
