Forums >> Revit Building >> Technical Support >> Converting curtainwall into wireframe
Wed, Jun 13, 2012 at 8:49:10 AM | Converting curtainwall into wireframe
kellyd94
Helllo all,
I am trying to take a curtainwall model that we got from an architect and convert it into a wireframe for export into AutoCAD. Does anyone know a way to convert a curtainwall mullion into a single line? Is it even possible? I only need lines representing the outline of the units and intermediate mullions, no system depth. Also, I am using Revit 2012.
Wed, Jun 13, 2012 at 9:22:16 AM | Converting curtainwall into wireframe
I would think a simple elevation view will give you this when exported.  Did you try it?
Wed, Jun 13, 2012 at 9:37:34 AM | Converting curtainwall into wireframe
kellyd94
I have not, but I should have added in my first post that the model needs to be 3-D.
Wed, Jun 13, 2012 at 9:42:09 AM | Converting curtainwall into wireframe
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So you are saying that you only want to see a single 2D line in a 3D model?
Wed, Jun 13, 2012 at 9:44:26 AM | Converting curtainwall into wireframe
kellyd94
Basically, yes
Wed, Jun 13, 2012 at 10:08:46 AM | Converting curtainwall into wireframe
That is a little confusing.  3D includes depth....
Export the elevation to CAD - 2D, then import that elevation into an elevation and don't check "this view only".  The linework will now be 3D.  DON'T EXPLODE!!!! But you can delete alyers you don't need.
Another way is to import into an elevation in a family and explode - delete what you don't want and make sure all linework is 3D.
Wed, Jun 13, 2012 at 10:09:01 AM | Converting curtainwall into wireframe
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
N.C.
Edited on: Wed, Jun 13, 2012 at 12:24:17 PM
Wed, Jun 13, 2012 at 12:09:08 PM | Converting curtainwall into wireframe
DG ^^^ Read above your post.
Wed, Jun 13, 2012 at 1:28:57 PM | Converting curtainwall into wireframe
kellyd94
The elevations will only work for two sides of the building as there is a corner of the building that has radiused units. Do you know if there is a way to export the curtain wall grid itself, without the curtainwall?
Wed, Jun 13, 2012 at 1:40:31 PM | Converting curtainwall into wireframe
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
No.
Wed, Jun 13, 2012 at 1:51:23 PM | Converting curtainwall into wireframe
Radiused curtain walls are just segmented curtainwalls.  You will have to do a seperate elevation for each segment ....
I still don't understand why you do this as a 3d wireframe...
Wed, Jun 13, 2012 at 1:55:17 PM | Converting curtainwall into wireframe
kellyd94
We need the 3-D wireframe for some in-house programs that derive their information from a 3-D wireframe in AutoCAD. I need to turn the outline of the units, with horizontals, into 3-D ploylines. From there, they are basically placeholders for information. The SF and LF for materials are calculated based on these "cells" and then materials and profiles are assigned and calculated based on that.
Wed, Jun 13, 2012 at 2:08:44 PM | Converting curtainwall into wireframe
#13
For "curved" curtain walls, I wonder where their work plan is?  Exterior face?
I suggest for curved curtain walls, you add 3D line work setting each plane as a work plane ... one at a time.... ouch!
Now that I understand your reason, I have a suggestion that should work.  Remove all the mullions and leave the glass panels.  Then export the walls in 3D mode.  This will give 6 planes for each panel.  In Autocad, go to plan views; cross the back plane and delete.  This will leave the front planes.
Curtainwall edit profile
Fri, Jun 12, 2020 at 7:48:21 AM
Revit 2013 - Can't Use Align Tool on Edge of Curtainwall
Fri, Oct 26, 2012 at 11:45:05 AM
Custom Curtainwall Tag from View Tag
Tue, Feb 26, 2008 at 9:17:54 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:36 AM
Temporary wireframe
Thu, Aug 26, 2010 at 12:14:56 PM
Page generation time: 0.0821
