6 Users Online (4 Members):
Forums >> Revit Structure >> Technical Support >> Help of Hatch Tile in a Ceramic Material
3 Posts No Rating |
Hi all,
sorry for the stupid question, but I have a problem:
I would like to use the same material for vertical finish (for interior wall layer) and horizontal finish (for top floor layer), the material have the Hatch Pattern of double square lines for surface (6in).
The problem is that in a 3D view I can see only in the wall finishing the above mentioned hatch and nothing in the floor finish.In Plan view is visible also in the floor and I can't understand the reason why....Could plese help me in order to see in the 3D view in both surfaces the same hatch?Many thanks in advance
In 3D views, you vision angle is too accute to the floor. Revit will not show patterns at accute angles.
3 Posts No Rating |
Many thanks for the clarification,
I also discovered to changed the visibility and Grafically of 3D view lines (erroneously) and when I removed this kind of modification the hatch appear correctly
Best Regards
I have this same problem but placeing 12"X24"X2" marble cubes and would like to vertical seems to show on the 2" thickness. But my problem is I didn't understand what you are saying.
Partial height Ceramic Tile |
Thu, Feb 23, 2012 at 9:31:28 AM
Ceramic Tile Flooring |
Wed, Jan 2, 2008 at 9:03:02 AM
Custom hatch of odd tile size |
Fri, Jul 20, 2012 at 5:27:57 PM
Material takeoff |
Sun, Feb 13, 2011 at 6:38:47 AM
Can Door/Window cut through multiple walls |
Wed, May 26, 2010 at 10:06:37 AM
