13 Users Online (11 Members):
Forums >> Revit Systems >> Technical Support >> linking files to a model
i have a need in Revit 2013 to attach files to equipment in the model. can this be done? and how? if possible i need to attach a pdf to a piece of equipment, then when opened up with design review it would have a link to the file.
Try to learn at least one new thing every day |
Can't use PDF's in Revit. Sorry.
sorry, i must not have been clear. i need to attach a link to the equipment so that when the file is opened in design review you can select the equipmnet and navigate to a pdf or word document. for example attaching a IOM to a boiler.
Create a text parameter in the family, and add the link to the PDF there. You'll have to copy/paste the link, but I don't know of any other way to provide a PDF with a family.
This is very do-able.
We just add a URL to the URL 'Type' parameter of the element.
The URL can be a network file / folder or a web based file / folder. As long as it's accessible.
After you add the URL to the Type parameter of the element click the element, then click the 'Edit Type' button, click in the URL field and a little button shows up on the right of the field. Click the little button and it open's the PDF or what ever the URL is pointing to.
We use this as a help method for content descriptions etc. see attached image.
I just wish there was a dynamic URL icon that shows up when you click on an element that has a URL instead of having to go through the properties palette. Perhaps there is a faster way to activate the associated URL once it gets applied to the element ??
See attached image.
Edited on: Tue, Jun 12, 2012 at 5:28:34 PM
thank you dgcad, that is exactly what i was looking for. i have a client that wants to be able to use the model in design review, or Naviswork freedom to look at the building on a daily basis and be able to pull up the IOM right from the model.
Linking Revit Files for Sheet Coordination |
Fri, Jul 10, 2009 at 11:09:09 AM
Linking large files |
Wed, Aug 31, 2005 at 2:32:01 PM
Linking Revit Architecture files |
Sun, May 12, 2013 at 11:05:15 AM
Linking Revit files |
Thu, Mar 25, 2004 at 5:49:40 PM
Linking models with multiple sites |
Wed, Dec 6, 2017 at 9:43:09 AM
