Forums >> Revit Building >> Technical Support >> Doors and Frames
Mon, Jan 2, 2006 at 8:44:52 AM | Doors and Frames
RunningProf
Any way to insert a door with a frame? When inserting a door Revit shows a 3' door but no frame. The total opening in the wall is only 3' not 3'-4". It then becomes diffulct to dimension door frame openings when frame is in masonry wall. Thank you.
Mon, Jan 2, 2006 at 11:57:37 AM | RE: Doors and Frames
dahlberg
try this door frame its a HM frame with a wood door that I made that is intended for Masonry walls. if you are still working with doors that Autodesks provides with Revit, you will learn quickly those doors are pretty much useless. You really should make your own set of doors. Whoever made the door perhaps didn't know that doors have frames and are typically 1 3/4" thick, not 2".. I am in the process of reviewing the families that I have generated. The attached file may not be completely worked out.. The lever handle that i made for it might not behave. But its a start for you to see a door that cuts a masonry wall so you can dimension M.O. Lemmeno know.what you think. Jim
Thu, Oct 11, 2007 at 11:25:58 AM | Doors and Frames
rat69
Is there a chance that you have an exterior Hollow metal door with variable width and height, and 4 inches top frame? (Maybe I am asking too much)
I will really appreciate your input
Thu, Oct 11, 2007 at 4:49:19 PM | Doors and Frames
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Check out this thread. I just posted it
http://www.revitcity.com/forums.php?action=viewthread&thread_id=8982
Door Families with HM frames that center on walls.
Thu, Sep 21, 2006 at 9:15:16 AM
Show Door Frames in Plan View
Wed, Aug 10, 2005 at 6:09:34 PM
Revit Walkthrough; between key frames
Thu, Jul 30, 2015 at 8:22:01 AM
Metal Door
Tue, Nov 30, 2010 at 7:27:10 AM
how to make door frames cut wall sweep? [ 1 2 ]
Mon, Jun 9, 2008 at 8:11:27 AM
20
Page generation time: 1.5354
