13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Overlap Exterior Siding Over Garage C.M.U. Footing...
6 Posts No Rating |
1.) The project is a garage renovation.
2.) It has a C.M.U. footing/retaining wall and I would like to overlap that footing/retaining wall with the siding from the wal.
3.) I currently have it drawn as only an offset "retaining wall"
Please refer to the attached image. Any suggestions?
Edit your wall and unlock the siding layer, then pull that layer down in section views.
Read your HELP on wall definitions if you don't understand.
In you wall type properties edit structure, switch your view to section, under Modify Vertical Structure click MODIFY, zoom in to the bottom of you wall and click on the line that represents your siding and unlock the lock button. Once you do that you will be able to drag your siding past your C.M.U.
WWhub beat me to it!
6 Posts No Rating |
Thank you both very much for your time and help!
Wall Sweep/Siding |
Sun, Feb 17, 2008 at 12:11:00 PM
revit 2015-exterior elevations horizontal lines of wood siding |
Sun, Dec 6, 2015 at 10:01:16 PM
Exterior siding below wall level |
Wed, Feb 17, 2010 at 3:37:03 PM
Live Footing Schedule - Linked Model |
Fri, Oct 9, 2015 at 10:15:06 AM
How do i add wood siding in the exterior wall? Need major help! |
Tue, May 15, 2018 at 9:57:18 AM
