Forums >> Revit Systems >> Technical Support >> Structural framing plan for a sloped roof?
Mon, Jun 11, 2012 at 6:47:38 PM | Structural framing plan for a sloped roof?
Debuta
I'd like to set up a structural framing plan for a sloped roof. Tried placing a level called structural roof level and playing with its view range, but no luck. Does anyone have any advice? Thanks
Tue, Jun 12, 2012 at 7:58:26 AM | Structural framing plan for a sloped roof?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What is the problem that you are running into?
Tue, Jun 12, 2012 at 9:43:27 AM | Structural framing plan for a sloped roof?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Not sure what the exact problem is but to start with creating a new 'sloped' reference plane (in an elevation or section view) and name the reference plane 'sloped Structural'. Then make set that as the current work plane and model the sloping members on that reference plane. The plan view just has to capture those objects in the view range.
Fri, Mar 29, 2013 at 8:23:18 AM | Structural framing plan for a sloped roof?
althouse08
I am trying to nest a parametric set of purlins into something similar to this, so that when I draw my roof, all detail components embed as well. I am having trouble, however, trying to align the nested purlin structure into a roof structure, as I can seem to get them to go at an angle. I attached a picture of what I am looking at. Thanks.
"The road to success is always under construction"
Fri, Mar 29, 2013 at 8:32:12 AM | Structural framing plan for a sloped roof?
Detail components are 2d.  Use model components.  They will cut correctly.
Fri, Mar 29, 2013 at 9:07:40 AM | Structural framing plan for a sloped roof?
althouse08
Am I missing something? I didn't know I used any detail components...I inserted my purlin model, other than that I am not sure what you are talking about "detail components"
Fri, Mar 29, 2013 at 9:53:50 AM | Structural framing plan for a sloped roof?
Sorry, I read this "...all detail components embed as well...".  That mislead me.
I'm not sure what you are asking and what you are doing. Perhaps this family will help you:
Roof Framing For Sloped Roof
Tue, May 5, 2015 at 5:48:41 PM
sloped roof framing
Fri, Apr 20, 2007 at 4:20:12 PM
Roof to follow sloped structural steel
Wed, Sep 22, 2010 at 4:11:16 AM
Sloped framing and framing plans
Tue, Apr 11, 2006 at 7:47:26 PM
Structural Framing Plans/Callout Beam Sizes
Wed, Feb 22, 2006 at 5:49:10 PM
Page generation time: 4.8842
