Forums >> Revit Building >> Technical Support >> Can't find ''Rectangle Panel - MPK''
Sat, Jun 9, 2012 at 3:46:51 PM | Can't find ''Rectangle Panel - MPK''
gogorevit
Hello, I'm following some instructions to create a custom curtain panel and it requires the file called  ''Rectangle Panel - MPK'', it says that it's in the Additional Files folder, but I can't seem to find the folder or the file anywhere... does anyone have that? It'd be much appreciated. Thanks in advance.
Sat, Jun 9, 2012 at 3:49:37 PM | Can't find ''Rectangle Panel - MPK''
gogorevit
I'm using revit 2013. The most I can find is the ''Curtain Panel By Pattern'' folder and in it there is a ''Rectangle Surface'' but I dont think that's what I'm after...
Sun, Jun 10, 2012 at 4:06:20 AM | Can't find ''Rectangle Panel - MPK''
4 Stars: 205 Votes
Are you following those instruction from any exercise book? To create a Curtain wall panel you only need the "Metric/Imperial Curtain wall panel" family template OR "Metric/Imperial Curtain Panel Pattern Based" if you are creating some patterns in Conceptual mass...
Thu, Apr 3, 2014 at 5:50:24 AM | Can't find ''Rectangle Panel - MPK''
arqmc
Go to step 5 and do the job there. If you want, you can copy the courtin back to your file and then it will appear on your family list.
Worked for me.
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Curtain panel - ''wont make type'' - Please help
Tue, Apr 23, 2013 at 8:10:58 AM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Sheet 'X' of 'Total Number of Sheets'
Wed, Jun 5, 2013 at 4:39:34 PM
Page generation time: 1.6376
