Forums >> Revit Systems >> Technical Support >> Cannot get the Mechanical-Default_Metric.rte template to load
Fri, Jun 8, 2012 at 4:50:33 AM | Cannot get the Mechanical-Default_Metric.rte template to load
Kristophon
Hi Folks... Ive used Revit a bit but never started a project from scratch
When I try to start a new project and load the template Mechanical-Default_Metric.rte its doesnt load. I just get the
basic default setup whish is useless.
When I open the template itself as a .rte file I can see the mechanical disiplines but when i try to start a .rvt it wont load
Please help... i`m pulling my  hair out!
Thanks
Kris
Fri, Jun 8, 2012 at 10:33:19 AM | Cannot get the Mechanical-Default_Metric.rte template to load
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Kris when you say " I load the template Mechanical-Default_Metric.rte its doesnt load" makes no sense to us.
Have you gone into the REVIT 'Options' dialog box to conform that the 'Mechanical-Default_Metric.rte' is in fact the DEFAULT template file when starting a new project ? If you clcik the 'New' button you are automatically put into a project using the above specified project template file. I could be wrong but t sounds to me like your default template file is NOT what you want. You can also browse to select the correct template file as you create a new project.
Fri, Jun 8, 2012 at 11:54:02 AM | Cannot get the Mechanical-Default_Metric.rte template to load
DESIGN4BUILDING
DESIGN4BUILDING Avatar
3.5 Stars: 3 Votes
what revit v is it 2013, or what. if you look in the library do you have all the fittings show up & stuff ??
Fri, Jun 8, 2012 at 12:15:36 PM | Cannot get the Mechanical-Default_Metric.rte template to load
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Again you are using incorrect 'terminology'. What do you mean by 'when you look in the library" what library ??? In REVIT a library is just a folder on the computer. There is no actual 'library'. Any folder can be a library. A USB stick can be a library. When you use the default mechanical project template file the basic families are pre-loaded into the project and listed in the 'project browser'. If you need more families then click the 'Load Family' button and load more families.
If you happen to have a pirated version of REVIT Then you may not have the families. If you have a proper installation the families are pre-loaded in the template file and or organized on your PC and available for loading. Do a search on your hard drive for *.rfa files. They should be there.
Fri, Jun 8, 2012 at 12:20:52 PM | Cannot get the Mechanical-Default_Metric.rte template to load
Kristophon
thanks chaps... thats sorted it. the option dialog box wasnt filled in right
Fri, Jun 8, 2012 at 6:23:24 PM | Cannot get the Mechanical-Default_Metric.rte template to load
DESIGN4BUILDING
3.5 Stars: 3 Votes
thats why i ask is what v, 2013 or what, 2013 should be loaded on line to get the library FOLDERS that you need or it will install with no templetes of anything. Just might be the prob. but i think he is on 12 not 13.
Sat, Jun 9, 2012 at 2:30:21 AM | Cannot get the Mechanical-Default_Metric.rte template to load
Kristophon
13 chaps
Revit Template File from Project file .rvt to .rte
Sun, Apr 28, 2013 at 1:35:39 AM
need help to load a rte file....
Tue, Mar 24, 2009 at 7:58:36 AM
Changing .rte template midstream
Thu, Feb 14, 2008 at 1:03:47 PM
template (.rte) or project (.rvt) files
Mon, Mar 20, 2006 at 3:16:44 PM
.Rte - View Template Settings - Reset Linked .Rvt Graphic Overrides
Tue, Feb 10, 2009 at 2:19:03 PM
Page generation time: 0.2149
