19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Pattern file location on drive
I want to put my downloaded pattern file into the patterns folder instead of on the desktop. where is it on my drive? I just can't find the pattern folder. I have revit 2011
By default are all in one file, "Revit.pat", search for that file... but you can create a pattern folder (wherever you want) where you can place the whole pattern files you have...
Your fill pattern code needs to be cut and pasted / incorporated into the *.pat file located in the c:\program files\ folder.
See attached image.
Thanks or both answers.
I ended up making a folder of my own. seems to work fine. I didnt know about the songle complete pattern file. seems dicey.
Warc.
Where does Revit 2014 store its fill patterns on the C: drive?
Did you do a search? You know the name.
For those like me that were looking for the answer and never found it on this board:C:\Program Files\Autodesk\Revit 2015\Data
Just so everyone knows, the location of this file has changed with almost every version of Revit. Attached image shows some of the locations.
Not enough hard drive space |
Sat, Jan 8, 2011 at 6:09:16 AM
11
.Pat file location |
Wed, Mar 18, 2015 at 11:31:27 AM
Need file location help for open command path |
Sat, Sep 11, 2010 at 5:27:16 PM
Automatically Render to a new location other than internal hard drive? |
Fri, Jun 6, 2008 at 1:29:29 AM
Saving Central files on local drive |
Thu, Apr 2, 2009 at 4:23:55 PM
