Forums >> Revit Building >> Technical Support >> Revit Project to Families
Thu, Jun 7, 2012 at 6:15:11 AM | Revit Project to Families
dev41113
Dear Revit Users,
I have created a Project file which has
a) Mass
b) Families and Nested Families
c) Walls and building components , such as stairs , lifts as components e.tc.
Theses things a spread across 5 levels and needs to be replicated atleast 14 times .
So I have created a Group and when I try to either copy the group or array the group, I get an error message saying
a) Constraints not satisfied
b) Delete elements
c) Group instances of the same type do not contain identical members.  Press "Fix Groups..." to select from options to make the groups consistent.
Corresponding group members in different group instances diverge in the following respects:
- Group members are missing in some group instances
- different positions relative to the group origin
Could any one help me ( this is the first time I am experiencing such an error message in the last six years of using revit)
I may be doing something wrong but am unable to locate the error.
Thu, Jun 7, 2012 at 7:44:10 AM | Revit Project to Families
Your error is hosted elements that can't find a host.
Replacing Multiple families in a Project.
Mon, Oct 15, 2018 at 10:34:29 AM
How to Load Multiple Families into Revit Project File in 1 Shot
Tue, May 28, 2013 at 8:31:09 PM
Inserting multiple Families causes project to freeze
Fri, Jul 11, 2008 at 3:28:40 AM
Edit Families Within A Project
Thu, May 1, 2008 at 11:48:38 PM
Saving all families from a project
Mon, Nov 18, 2013 at 1:23:16 PM
Page generation time: 1.9309
