Forums >> General Discussion >> Revit Project Management >> Rotating door
Wed, Jun 6, 2012 at 1:08:54 PM | Rotating door
MarceloPazdaCordeiro
4 Stars: 8 Votes
I wonder if anyone has any rotating door for me to download, in the Brazilian standard.
Thu, Jun 7, 2012 at 11:23:14 AM | Rotating door
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you looked in the downloads here under "revolving door"?
Fri, Jun 8, 2012 at 12:08:11 PM | Rotating door
4 Stars: 8 Votes
Yes, I tried in several places with different names, bad acho.Gostaria specific models I do not like something, there are the links below.
http://www.google.com.br/imgres?imgurl=http://www.wwillian.com.br/pivotante3.jpg&imgrefurl=http://www.wwillian.com.br/madeira_porta_pivotante.html&h=357&w=273&sz=19&tbnid=YzbvEpoVX5FIoM:&tbnh=90&tbnw=69&prev=/search%3Fq%3Dporta%2Bpivotante%26tbm%3Disch%26tbo%3Du&zoom=1&q=porta+pivotante&usg=__o8cGf_cY1tStBFQ5VBMRqJqbgGw=&docid=RyH4U8_P34euOM&hl=pt-BR&sa=X&ei=GjHST4jbEuWJ6gHNy5WUAw&sqi=2&ved=0CHUQ9QEwAg&dur=384http://www.google.com.br/imgres?imgurl=http://www.asaber.com.br/wp-content/uploads/2010/04/porta-de-luxo1.jpg&imgrefurl=http://www.asaber.com.br/portas-com-pivotantes-metodo-de-fixacao/&h=741&w=556&sz=80&tbnid=HwajAt4rEqBxjM:&tbnh=91&tbnw=68&prev=/search%3Fq%3Dporta%2Bpivotante%26tbm%3Disch%26tbo%3Du&zoom=1&q=porta+pivotante&usg=__OKkzHSxy7xQx5WX42yamzJAupEE=&docid=zl-d2kuGwPHZ8M&hl=pt-BR&sa=X&ei=GjHST4jbEuWJ6gHNy5WUAw&sqi=2&ved=0CHsQ9QEwBA&dur=216
Fri, Jun 8, 2012 at 12:51:31 PM | Rotating door
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Wow, cool doors. Very nice.
I have not personally seen this type of door family. You may have to make it yourself. Not hard to do. Just open and modify an existing door and change the 'detail lines' to pivot at a different point.
Fri, Jun 8, 2012 at 1:00:51 PM | Rotating door
4 Stars: 205 Votes
You have a few here in download section, check this member "Cesarita":
Ele é Português e criou algumas destas portas, sei que ele tem mais mas penso que as queira vender...
http://www.revitcity.com/downloads.php?action=search&user_name=cesarita&exactname=Y
http://www.revitcity.com/downloads.php?action=view&object_id=8512
Sat, Jun 9, 2012 at 6:40:34 AM | Rotating door
4 Stars: 8 Votes
The pivoting part is optimal, is exactly the model you want, the part of the amendment is not a problem, thank you my dear friends. thank you very much.
Sat, Jun 9, 2012 at 7:08:21 AM | Rotating door
4 Stars: 8 Votes
Very good doors, was a very big help, work in an office and Revit Architecture is little known here in Brazil yet. Bad to help I will also edit and put the doors here at Revit City.
Edited on: Sat, Jun 9, 2012 at 10:29:06 AM
Thu, May 8, 2014 at 11:28:05 AM | Rotating door
olivermason
Not sure but try at caldwells.com, there is possibility that they have that kind of door because they specialized in selling wide array of house doors including cabinet.
Cannot find the model or family I just imported!
Sat, May 20, 2017 at 1:27:21 PM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Page generation time: 0.2022
