Forums >> Community >> The Studio >> Components
Fri, Dec 30, 2005 at 11:45:23 PM | Components
bowlr
Can you create new components like furniture items etc using Revit?
Sat, Dec 31, 2005 at 6:45:18 AM | RE: Components
zanzibarbob
3 Stars: 1 Votes
Yes, Do the tutorials on the family editor.
Sat, Dec 31, 2005 at 10:31:08 AM | RE: Components
arquia
2.5 Stars: 9 Votes
yes you can create new elements using the family editor or you can change the atributs of the existent library.
Thu, Jan 5, 2006 at 8:49:58 PM | RE: Components
bowlr
But it seems that you are limited to the parametric objects that come with Revit or some that may be downloaded, but if you want a particular piece of furniture, eg, desk, cabinet you can't simply draw it in 3D and use it
Fri, Jan 6, 2006 at 2:24:22 AM | RE: Components
jobcaptain
jobcaptain Avatar
1 Stars: 2 Votes
When you use the Revit OPEN command, make sure you visit the WEB LIBRARY located on the button in the upper right corner of the dialog box....tons of furniture, equipment, with a high level of detail. or use this link http://revit.autodesk.com/library/html/index.html Tip: On each page of components, there is a filing cabinet icon in the upper right corner of the webpage. If you pick the filing cabinet button, you can download a zip file that contains all of the objects on that page...some zip files are 16MB - 26MB in size...tons of realistically detailed architectural components. The Revit family editor is pretty cool as a parametric solid modeler....it allows you to create variations of your furniture or equipment in one file. We sometimes use contract furniture manufacturers' 3D furniture from their websites/CD and "Revitize them" from AutoCAD 3D blocks into Revit Families. The benefit of turning it into a Revit family is I can add parameters that allow me to create Revit schedules (furniture, equipment, ) based on the parameters assigned to the component. I've posted some other suggestions on my blog site: www.taylor-tech.com/danielhughes I have an Archive button at the bottom of the main blog page. Past posts: How can I use my AutoCAD or Microstation files in a Revit-based Project? http://taylor-tech.com/blogs/getEntryById/54/entry.html Revit's 10 Best ROI Features for Your First Pilot Project http://taylor-tech.com/blogs/getEntryById/32/entry.html Cheers!
LinkedIn Profile:
  • http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com
Components on Level are Grey
Wed, Apr 17, 2013 at 12:56:06 PM
problem loading components
Sun, Apr 26, 2009 at 2:21:18 PM
transferring components
Tue, Jul 29, 2008 at 3:51:00 AM
Visibility/Graphics and Detail Components
Wed, Feb 23, 2011 at 2:53:36 PM
deleting old components
Sat, Apr 11, 2009 at 12:28:12 PM
Page generation time: 2.8104
