Forums >> Community >> Newbies >> Tag for "count"
Tue, Jun 5, 2012 at 12:16:57 PM | Tag for "count"
broigutt
Hi
I am trying to create a Tag for the count of my beams on a fabrication drawing..
It doesnt seem to be possible the normal way
does anyone know any workaround?
Tue, Jun 5, 2012 at 12:22:15 PM | Tag for "count"
Tags will not count.  You can get counts from schedules.
Wed, Jun 6, 2012 at 3:37:50 AM | Tag for "count"
broigutt
Yeah that is what i had figured out!I have already made the schedules with all the counts but i need the numbers on my fabrication drawings.
but do you know if there are any workarounds?.
like making a parameter that somehow makes a number equal to the count of the elements!?
This would be something for the Autodesk programmers to work on because i think this could be a popular option if possible
Wed, Jun 6, 2012 at 6:52:06 AM | Tag for "count"
Not sure what you are asking.  You can give elements mark numbers and that can be tagged.  The numbering would be manual unless you can find an add-on to do it.
You can always place the schedule on your drawing.
Wed, Jun 6, 2012 at 2:18:59 PM | Tag for "count"
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
i use macros that copy counts into tags for seating, occupancy loads and factors.
Mon, Jun 11, 2012 at 12:48:54 AM | Tag for "count"
Nicincad
Alabaster, I took a look at your site and your blog, are all your work done in Revit?
Schedules - Calculated Value does not have "Count" in the list of fields
Thu, Oct 17, 2013 at 8:55:44 PM
Schedule Count as Percent of Grand
Thu, Dec 22, 2011 at 10:33:17 AM
Room Schedules: Using "Count" in Calculated Vaules....???
Fri, Dec 10, 2010 at 1:02:21 PM
Window Schedule: "Count" not counting...
Tue, May 31, 2011 at 3:29:57 PM
"Tag by category" of Architectural Column in Plan
Thu, Apr 16, 2009 at 2:45:20 PM
Page generation time: 4.5920
