16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Door Hardware
How do you handle door hardware in the door properties box. I guess you need to put a key in "comments". Other ideas? Also, is there any way to have Revit report the door handing to the schedule?
-Steve Brown
admin
to answer all your questions...add additional parameters to your door families. You can add a parameter called "handing" and another one called "lockset" and so on... Then in your project you can fill in these fields.
Hiroshi Jacobs
The Catholic University of America |
yes, thanks. But doesnt this require modifying every door file?
Steve
admin
yes but you didn't expect to not have to do any work did you? :-) What we do is give doors a hardware group and just call out the hardware group in the comment. Hardware groups are specified in our specs.
Hiroshi Jacobs
Agreed on the hardware group in the comments. Any way to have the "hand" of the door reported?
admin
as far as the door handing, it's probably best to set your doors up with an instance shared parameter.
Hiroshi Jacobs
Have a look ot Xdoor.
https://apps.autodesk.com/RVT/en/Detail/Index?id=2481590927896495348&appLang=en&os=Win64
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
I got this interior door http://caldwells.com/interior-doors/closet-doors at Caldwells hardware and door shop, you can check them as they also offers several door accesories and other home improvement needs.
Door hardware Schedule |
Fri, Dec 2, 2011 at 11:01:22 AM
Door Hardware and Accessories |
Thu, Mar 29, 2007 at 8:33:27 AM
Door Hardware |
Wed, Nov 16, 2011 at 7:27:32 AM
Door Hardware and accessories |
Wed, Mar 28, 2007 at 10:15:46 AM
Door schedule |
Sat, Nov 8, 2014 at 7:47:17 AM
