Forums >> Revit Building >> Technical Support >> Rounding down dimensions.
Mon, Jun 4, 2012 at 2:27:21 PM | Rounding down dimensions.
dawingthedream
I am working on athe CD for a new condominium development. When creating the interior dimensioned plans that will be used by the listing agent, we are hoping to round down dimensions to the nearest inch in order to avoid falling short of "promised" dimensions per the offering plan.
Any ideas of how to modify the dimension settings to round down to the nearest inch?
Thanks!
Mon, Jun 4, 2012 at 7:07:28 PM | Rounding down dimensions.
agosztyla
Go to project units under manage in your toolbar
Tue, Mar 14, 2017 at 7:31:04 AM | Rounding down dimensions.
mraccu
Old but gold for newbies.
Thank you
Tue, Mar 14, 2017 at 9:23:13 AM | mraccu
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting mraccu from 2017-03-14 07:31:04
Thank you
FYI, project units under manage tab will change the units globally, but you can also change the dim setting for only one specific dim type. Select the dim you want to change, go to edit type, duplicate, rename, and click on the value next to the units format under text, uncheck use project settings and adjust your rounding.
Dimension Rounding
Thu, Aug 23, 2007 at 2:54:31 PM
How to set custom unit conversion value
Thu, Jul 17, 2014 at 5:27:32 AM
Rounding in Formulas
Wed, Mar 13, 2013 at 8:49:48 AM
Area Tags - Rounding refuses to change
Tue, Feb 10, 2015 at 8:22:13 PM
Rounding Issue in Schedules
Mon, Jan 9, 2017 at 2:07:07 PM
Page generation time: 0.1193
