15 Users Online (13 Members):
Forums >> Revit Systems >> Technical Support >> Detaching file from central and working individually
4 Posts No Rating |
Hello,
My boss gave me a file that I need to continue working on. The problem is that before the worksharing function was enabled.
Of course, I read some guides how to detach it and I went to File-Open-Deatch and I saved it with a separate name. Then I was able to use it.
I copied this file and today I wanted to work from another pc and it told me that the connection with the central file is missing. Actually, I thought that with detaching it from the central file, this rvt is a file like any other that has never been connected to a server.
It is only me who is going to work on this file. Can you give me a solution of the problem as i want to work in the office and at home without having to synchronize and to find a server?
Thanks in advance.
There is a topic in your HELP that discusses how to do this: Working Offsite and Offline I suggest you start by reading this.
We work offsite my connecting to our netwrork and logging into our work PC. This is a better method than what is suggested in the HELP.
can't view file properties - central path |
Fri, Aug 21, 2009 at 2:34:53 PM
Detaching from Central Model...I CANT! |
Fri, Aug 27, 2010 at 10:26:55 AM
Can't share central file |
Mon, Nov 23, 2009 at 4:07:18 PM
Central/Local File Synchronizing Issue |
Sun, Jun 23, 2013 at 2:33:20 PM
Central File Path on a local file |
Sat, Oct 24, 2015 at 10:21:20 AM
