10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Can Revit draw a vertically sloped axi line?
85 Posts No Rating |
One wall of my building is a sloped wall, I don't know how to draw axi lines along to this sloped wall. See ,my cad drawing, the axi B and axi C are constant changing with different floors, because the walls wihch they noted are sloped walls, it seems that Revit cant not make a sloped axi according to the wall.
沧海月明珠有泪 |
Correct me if I'm wrong, you mean "Grid Lines"? those "Axi Lines" B and C are grid lines and you want to draw that in your plan view in Revit like you have in CAD file?
If you want Vertical Grid Lines goto a Elevation / section view and create them.
Also, take a look at your HELP menu: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0135-Prelimin135/0137-Levels_a137/0149-Grids149
Edited on: Mon, Jun 4, 2012 at 6:06:51 AM
This picture shows what I mean, see the first blue wall, it is vertical, so the axis A in the wall will be in the same places when Floor 1 and Floor 2 cut the blue wall. While the second gray wall, it is sloped, so the axis B in the wall shows the different palces when Floor 1 and Floor 2 cut the gray wall. B and B' are in the same places in the Floor 1 and Floor2 because of the vertical cut plane.
What I mean is that , it seems Revit axis only shows like the blue wall, the same axis number show in the same places in different floor plans, But is there any ways to show the same axis changing places according to different floors plans because of the sloped wall which like the my gray wall?
沧海月明珠有泪 |
Think about this. Where exactly would you show this axis in a floor plane? At the point where it crosses the floor plane, at the level of the view cut, where? And wherever it is, what good is it to the reader? How can he use this in understanding the building?
Sorry but this has no real value in documenting a building. What would have value is the grid points at the base and those at the top.
Sloped joist line type |
Thu, Nov 25, 2010 at 12:25:02 PM
Sloped line |
Mon, Apr 17, 2006 at 7:42:08 PM
Pendant Lights on a sloped ceiling |
Thu, Sep 12, 2013 at 9:19:42 AM
sloped walls |
Wed, Oct 13, 2010 at 1:28:16 PM
How to draw this property line? |
Sat, Jan 23, 2016 at 4:48:18 PM
