Forums >> Revit Building >> Technical Support >> elevation title tages with the same title
Thu, May 31, 2012 at 4:37:18 PM | elevation title tages with the same title
sgray05
is there a way to override the detail title such that I have multiple tages with the same name. for instance. I have the 4 room elevations but want them all to be named room 101 elevation. they will be identified and keyed based on the number
Fri, Jun 1, 2012 at 6:57:40 AM | elevation title tages with the same title
Please learn to use your HELP.
View Name -  The name of the active view. The view name displays in the Project Browser and in the title bar of the view. It also displays as the name of the viewport on a sheet, unless you define a value for the Title on Sheet parameter.
All Project Browser names MUST be unique.  But ... read the last part above ^^^^
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
view title on sheets
Thu, Nov 22, 2018 at 8:28:28 AM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Going from "Title w line" to "Plan Title"
Thu, Aug 23, 2007 at 11:53:11 AM
title bar
Mon, Sep 1, 2008 at 1:01:59 PM
Page generation time: 0.3164
