Forums >> Revit Building >> Technical Support >> exterior glazing systems
Thu, May 31, 2012 at 8:28:51 AM | exterior glazing systems
marcomac
Hi There
I would like to create a Storefront/Curtain wall/ Exerior glazing that creates vertical grids and 2 x horizontal grids at set measurements. this wall also needs to make the bottom panel solid as I draw the wall.
If anyone can tell, show or direct me to a tutorial that can teach me this it would be much appreciated.
Regards
marco
Thu, May 31, 2012 at 8:42:58 AM | exterior glazing systems
You are not clear in your question.  The answer to the one that you have written is:
Simply create a new CW type that has a fixed spacing for the horizontal and the vertical grids.
I am sure that is probably not your question.  If you mean a pattern of different spacings? ... Then the answer is you can't.  Simply create one, then copy it to other locations and edit accordingly.
Rendering Exterior Glazing
Mon, Feb 20, 2012 at 2:45:05 PM
Mullion offset from exterior glazing
Sun, Feb 14, 2010 at 10:05:21 AM
transparency on exterior elevations
Mon, May 21, 2007 at 5:51:15 PM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
Problem with glazing and wall alignments
Thu, Jan 24, 2013 at 10:16:59 AM
Page generation time: 0.1301
