Forums >> Revit Building >> Technical Support >> Saving 3d views
Wed, May 30, 2012 at 5:43:12 PM | Saving 3d views
vanderloo
Trying to remember how to save 3d views in Revit. Seems like it should be easy. (I'm sure it is).
Thank You
Wed, May 30, 2012 at 11:19:57 PM | Saving 3d views
Warchitect
4 Stars: 5 Votes
Well you can export them to Jpeg.
you can print to PDF
you can use the render window to create renderings and those views gets saved in the browser.
otherwise its a right click on the view and create a duplicate view.
Thu, May 31, 2012 at 3:31:54 AM | Saving 3d views
4 Stars: 205 Votes
Open the "3D view", go to the big "R" then Export > ... (DWG, DXF, DGN...  format you want)
Fri, Jun 1, 2012 at 10:00:27 AM | Saving 3d views
vanderloo
I was hoping to save it as a view so I can drag it into a sheet.
Fri, Jun 1, 2012 at 10:12:59 AM | Saving 3d views
It is a view, just place it on your sheet.
If you mean your default 3D view, just change the name, then place it.  The next time you click on the house icon, you will see a new 3D view. ...Or you can just copy the default 3D view and rename it.
Fri, Jun 1, 2012 at 10:33:28 AM | Saving 3d views
vanderloo
But it's not locked. Every time I go into the 3d view and change the orientation it changes on the sheet. I want it locked on a specific position.
Thanks
Fri, Jun 1, 2012 at 10:41:24 AM | Saving 3d views
AS I POSTED:  If you mean your default 3D view, just change the name, then place it.  The next time you click on the house icon, you will see a new 3D view. ...Or you can just copy the default 3D view and rename it.  Just don't rotate it anymore!
You can lock a perspective (camera) 3D view in the latest release.
Fri, Jun 1, 2012 at 11:00:02 AM | Saving 3d views
vanderloo
Thanks WWHhub. I knew it would be something simple.
Fri, Jun 1, 2012 at 11:48:03 AM | Saving 3d views
Warchitect
4 Stars: 5 Votes
The trick for me is to name the duplicate 3D views with names like "view of kitchen" or "view towards Master bathroom" then I know those aren't the ones that need to be the working 3d view where you rotate and look at the model.
ie. you can right click on the 3d view in the browseer and pick "duplicte view", or create perspective views with the camera tool. both reside in the 3d secion of the browser. where they can be placed on sheets.
Fri, Jun 1, 2012 at 5:25:02 PM | Saving 3d views
TKennedy
4 Stars: 8 Votes
Also, in 2012 there is a 'lock' button that will lock the orentation of the view so you cannot accidentally rotate the view.
saving views for use in another project??
Tue, Jan 23, 2007 at 3:28:05 PM
Saving drafing view ends up blank
Tue, Mar 18, 2014 at 10:30:40 AM
local file saving location [ 1 2 3 ]
Thu, Jul 10, 2008 at 8:03:09 AM
38
saving in previous releases
Wed, Oct 11, 2006 at 3:44:32 PM
Saving to Central
Thu, Mar 12, 2009 at 9:42:05 PM
Page generation time: 1.3682
