Forums >> Revit Systems >> Technical Support >> Importing IFC into Revit MEP 2013
Tue, May 29, 2012 at 4:56:40 PM | Importing IFC into Revit MEP 2013
heinzk1
We have an Architect using the Bently V8 program and has exported out their models in many different IFC formats buteverytime Revit opens the IFC format something has to be unjoined or deleted and then the models dont appear right.
Is there anything else we can try to get this to work?
They have demolition walls that just wont come through and I downloaded a viewer that shows they are there.
Very frustrating,
Heinzk1
Sun, Jun 3, 2012 at 5:36:20 AM | Importing IFC into Revit MEP 2013
4 Stars: 205 Votes
I don't know if this solve your problem but: http://www.revitcity.com/forums.php?action=viewthread&thread_id=27528
Tue, Jun 5, 2012 at 11:32:51 AM | Importing IFC into Revit MEP 2013
heinzk1
Thanks for the information but I tried the plug-in and it's a one-way conversion.  It only let me save to Bently's product
but not import it back.
Sincerely,
Heinzk1
Wed, Jul 11, 2012 at 7:40:52 AM | Importing IFC into Revit MEP 2013
JCampbell924
Do you know if they are using a mapping table when they create the IFC file out of Bentley Architectural\Bentley AECOSIM?  I have found with other applications that I have to match how they are setting up the export map with my import map.  If they are not changing the map table I think from what I remember Bentley Arch will map the pre-made demo wall to the IfcWallStanddardCase.
importing IFC files in to MEP 2011
Mon, Feb 11, 2013 at 10:53:22 AM
IFC IMPORTING
Thu, Feb 23, 2012 at 5:16:29 PM
Inserting IFC into AutoCAD MEP
Tue, Feb 12, 2013 at 2:01:28 PM
IFC Color Change?
Fri, Nov 9, 2007 at 10:46:21 AM
exporting and importing ifc
Wed, Oct 21, 2009 at 7:06:12 AM
Page generation time: 2.4244
