Forums >> Revit Building >> Technical Support >> 2013 multicore usage
Mon, May 28, 2012 at 9:47:31 PM | 2013 multicore usage
ScubaMan
I have been looking on the forums and have not found an updated post on Revit using multiple cores. The most updated post I have found regarding this mater stop in Revit 2011. From what I know Revit still does not use multiple cores or even the threes that go with the cores in the new i7. If someone could just confirm this for me that would be great. The best post I have found on this matter for older version if anyone is interested is http://revitcity.com/forums.php?action=viewthread&thread_id=14245  Thanks guys and have a good day,
Tue, May 29, 2012 at 4:50:30 AM | 2013 multicore usage
4 Stars: 205 Votes
Maybe this can help you: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14633072&linkID=9243099
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Rendering-processor-core-limit-for-Revit-2011-products/m-p/2787300/highlight/true#M47065
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Multi-Core-Processors/m-p/2669183/highlight/true#M43344
Tue, May 29, 2012 at 12:02:52 PM | 2013 multicore usage
ScubaMan
Thanks Typhoon that does help.
I was just hoping Autodesk allowed Revit to use all the cores for the everyday task not just rendering.
Thanks for taking the time to help out
hiding part of a usage tag
Tue, Aug 19, 2008 at 1:00:00 PM
structural usage for stacked walls
Tue, Jun 30, 2015 at 6:59:56 PM
memory usage in Revit 7
Tue, Jun 21, 2005 at 6:04:55 PM
Rendering not using full 100% CPU
Thu, Nov 21, 2013 at 10:55:27 AM
REVIT 2013 - Not ends render - FULL video memory usage
Fri, May 10, 2013 at 2:20:35 AM
Page generation time: 0.1117
