Forums >> Revit Building >> Technical Support >> Lights
Mon, May 28, 2012 at 2:58:32 PM | Lights
vhugomg
Ok.. I undestand the way revit works when you are making a ceilings plan with all the light fixtures attached to the ceiling hosts.. but what about the lights that I need to specify that goes on the floors (ground floor), iluminating a wall or some three from the floor level.
If the light families only works on ceilings, what can we do for this lights on the ground floor? I do not want to cheat making them with detail lines or model lines or symbols I wish to be able to use a lighning fixture family of a light that can be attached to the ground floor... Any suggestions? (maybe I am missing something)
Thanks a lot!
Tue, May 29, 2012 at 5:02:26 AM | Lights
4 Stars: 205 Votes
"I wish to be able to use a lighning fixture family of a light that can be attached to the ground floor... " - You have that kind of families in your lighting library already created OR you can crete your owns, also, if you search in our download section you'll see some of them...
http://www.revitcity.com/downloads.php?action=search&keywords=floor+light&user_name=&sort=score
Ceiling Lights don't self-illuminate
Mon, Oct 17, 2011 at 10:21:44 AM
Lights not acknowledged?
Thu, Jun 23, 2011 at 7:03:41 AM
Revit always renders all of the lights
Fri, Aug 8, 2014 at 9:24:36 AM
artificial lights not rendering
Tue, May 7, 2013 at 6:52:56 AM
exporing revit 09 to 3ds max with lights???
Tue, Jun 2, 2009 at 5:53:27 AM
Page generation time: 0.7866
