Forums >> Revit Building >> Technical Support >> Revit - Bentley Microstation Plug-in
Sun, May 27, 2012 at 6:48:53 AM | Revit - Bentley Microstation Plug-in
4 Stars: 205 Votes
The i-model plug-in for Revit allows users to save their Revit models in a way that lets users open them in Bentley MicroStation, Bentley Navigator, and many other Bentley building products, retaining the Revit properties information from the Revit model. The plug-in is designed to help teams working in a mixed Bentley/Revit environment to be able to reference Revit models into a MicroStation-based design workflow for coordination purposes, interference detection, and similar tasks.
How it works:The i-model plug-in for Revit lets users save their Revit models to an i-model file from within the Revit application. This is a one-step process that does not require MicroStation or any other Bentley application other than the i-model plug-in for Revit. The i-model can be used with Bentley Navigator for redlining, interference detection, and other federated information workflows. The plug-in works with the 2008-2012 versions of the Revit products, including Architecture, MEP, and Structure, and includes support for the 64-bit versions.
Download here: http://www.bentley.com/en-US/Promo/Revit/i-model.htm
Revit/ Bentley integration - is it better yet? Comments or suggestions welcomed
Thu, Aug 13, 2009 at 7:53:11 AM
Help - Importing 3D Bentley to Revit (.dwg or .dgn to .rvt)
Mon, Jun 2, 2014 at 7:53:20 AM
Revit to Bentley BIM
Fri, Mar 22, 2013 at 5:44:59 PM
Converting Revit to Bentley
Fri, Aug 22, 2008 at 10:52:38 AM
3D PDF inclusive material textures
Tue, Jun 25, 2013 at 2:28:04 PM
Page generation time: 1.5021
