Forums >> Revit Building >> Technical Support >> Title block gets cut off when plotting
Sat, May 26, 2012 at 12:19:31 PM | Title block gets cut off when plotting
Jeffm
I am using Revit 2012 and plotting on an older HP 650C plotter. When I plot it cuts the leading edge of the title block. I checked the size of the sheet (24x36) and it matches the plotter size selected. The plotter works perfectly with AutoCad.
I do not see where any margins are set. Could this be the problem?
Any suggestions would be appreciated
Sat, May 26, 2012 at 1:30:10 PM | Title block gets cut off when plotting
4 Stars: 205 Votes
I don't know if the problem is the machine, drivers.... create a PDF and a DWF of that drawing, print them and check if one of them print correctly.
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Sheet title block plots incorrectly
Wed, Nov 3, 2010 at 10:44:30 AM
Revit 7.0 Plotting
Thu, Jul 28, 2005 at 3:15:59 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:23 AM
Page generation time: 1.9183
