Forums >> Revit Building >> Technical Support >> Door tags
Thu, Dec 29, 2005 at 3:19:51 PM | Door tags
carlosgt
In my office, we use to label doors as 2068 (2' wide by 6'8" high), 2868, 3068 etc. is there any way to do the same in revit? Thanks.
Thu, Dec 29, 2005 at 3:48:42 PM | RE: Door tags
TomDorner
4.5 Stars: 25 Votes
The short answer is automatically no. Could be possible if string manipulation functions were present in Revit, but they are not. You could just place a type mark in each door family that displays the size as 2068 and create or choose a door tag to display that information. Remember, Revit is a database and the tag you choose to use will display the properties you define. This is in stark contrast to CAD systems where the tag holds the properties rather than being a mini database report of the properties of the object. HTH Tom
Door Tags
Mon, May 12, 2014 at 8:31:35 AM
Accessing Room Data in Door Tags
Mon, Jan 28, 2013 at 9:42:59 AM
Door tags and Door Type ID
Wed, Jul 10, 2013 at 1:40:25 PM
Door and window tags
Thu, Nov 3, 2011 at 8:51:34 AM
Room Window and Door Tags
Thu, Nov 15, 2007 at 9:21:10 PM
Page generation time: 8.4710
