Forums >> Revit Building >> Technical Support >> Loading Families into a project after a change - Always necessary?
Fri, May 25, 2012 at 11:49:27 AM | Loading Families into a project after a change - Always necessary?
britc
When I make a change to a family that has already been loaded into a project, do I HAVE to load into project to see the change? My main reason for asking is, I am in the process of creating some typical pieces and lets say I make a change to somethingthat is in several projects...do I have to go in and re-load it into all projects or upon opening a project (after the change has been saved)will it be reflected in the older projects?
Thanks!
Fri, May 25, 2012 at 11:58:22 AM | Loading Families into a project after a change - Always necessary?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You will need to reload the family to see the change.
Fri, May 25, 2012 at 12:06:18 PM | Loading Families into a project after a change - Always necessary?
Once loaded, all families exist in the project and are completely independent of your library.  They are not linked elements.  This is also true for your template.  All families in that are also not linked.
Differences in families while loading them into project
Wed, Oct 27, 2010 at 7:02:17 AM
How to change colour of a download from RevitCity
Wed, Apr 27, 2011 at 8:39:37 PM
11
Loading Families
Tue, Apr 21, 2009 at 4:41:24 PM
Unable to load conceptual mass into project
Fri, Sep 11, 2015 at 1:40:26 PM
Loading Families
Mon, Nov 23, 2015 at 7:25:45 AM
Page generation time: 4.4952
