13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Edit profile on a sloped wall
I am working on a very complex mass that has walls that are angled in both the x and z directions. I want to be able to create two different walls on a single face, but Revit will only allow me to apply a wall to the entire face. Is there some sort of work around for this? I have already tried splitting the mass faces.
Im using Revit 2012
Edited on: Fri, May 25, 2012 at 8:34:32 AM
Can you attach a pic of the mass you are using. If you split the face of the mass you should have 2 different faces and be able to apply a wall per face
Don't forget you can use "In-Place" families too....
Here's a pdf of the mass. I've also attached the file I'm using.
In Place familes wont really work because Im layering so many walls onto the mass.
Keep in mind when designing a structure that someone has to build it. They are tough enough when done simply.
How to Edit Profile of Sloped and Curved Walls? |
Thu, Sep 13, 2012 at 11:59:07 AM
Sloped terrain and sloped foundation wall |
Thu, Sep 3, 2009 at 1:57:36 PM
Sloped wall - mass in place - profile line level |
Thu, Oct 18, 2018 at 8:55:41 AM
edit wall profile... what? |
Mon, Feb 7, 2011 at 1:58:19 PM
Edit profile on a curved wall |
Sun, Aug 29, 2010 at 11:30:00 PM
