Forums >> Revit Structure >> Technical Support >> Lattice Girder Column
Thu, May 24, 2012 at 3:08:35 PM | Lattice Girder Column
lbarnett83uk
Hi All,
This is my first ever post on Revit City. I am currently trying to draw a 25m high warehouse with lattice girder trusses. What is the best way to draw these? Should I produce these as a family?
Thu, May 24, 2012 at 3:37:13 PM | Lattice Girder Column
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It depends on how detailed you want your model to be.  If you are going to be seeing the trusses in 3D then I would try to create a family for your truss.  Otherwise if its just sections you might be better off just detailing with lines.
Thu, May 24, 2012 at 3:38:42 PM | Lattice Girder Column
I would do them as a family (non-parametric) with all of the lattice done as one sketched extrusion in elevation.
The question is do you do the lattice as two planes? that would be easy.  Do one and copy - rotate for the other side.
Fri, May 25, 2012 at 3:05:49 AM | Lattice Girder Column
lbarnett83uk
Thanks guys!
I plan to draw it all in 3d, is there a way to make the lattice frame parametic so it can be altered in the model should the engineer change his mind?
Fri, May 25, 2012 at 6:36:25 AM | Lattice Girder Column
You could make the lattice a lot bigger in both dimensions, then use a parametric void mask to cut it...BUT Voids can start to overload models and I would not waste my time doing it.  I would just edit the family if the engineer changes sizes.
Lattice Under Decks
Thu, Apr 10, 2008 at 9:47:32 AM
Make Girder adjust with column Height
Thu, Oct 20, 2011 at 3:03:35 PM
coping the girder
Sat, Nov 13, 2010 at 3:16:50 PM
Modifying Existing Family
Thu, Nov 25, 2010 at 12:29:15 PM
locking an array overconstraints?
Fri, Sep 10, 2010 at 10:29:51 AM
Page generation time: 4.2627
