Forums >> Revit Building >> Technical Support >> Transparency problem. Inserting tif's for decals, the transparent background...
Thu, May 24, 2012 at 8:28:13 AM | Transparency problem. Inserting tif's for decals, the transparent background...
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
...comes in not transparent. Same with png's.  Do jpegs even support transparencies?  What am I doing wrong?
Thu, May 24, 2012 at 8:35:42 AM | Transparency problem. Inserting tif's for decals, the transparent background...
There have been several post on using jpg's for stained glass windows and backlit sighs.  Search for those and see what they found out.  I don't think Revit supports transpared jpeg backgrounds.
Thu, May 24, 2012 at 8:42:58 AM | Transparency problem. Inserting tif's for decals, the transparent background...
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
It doesn't support transparent tif's and png's either.  This is photoshop 101 image manipulation.  Why not?
Thu, May 24, 2012 at 10:36:47 AM | Transparency problem. Inserting tif's for decals, the transparent background...
4 Stars: 205 Votes
"It doesn't support transparent tif's and png's either." - Not true, revit can use PNG files (not jpeg) to be transparent, like WW said you can find several threads about this issue in the forum.
Thu, May 24, 2012 at 10:44:05 AM | Transparency problem. Inserting tif's for decals, the transparent background...
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Do you have a link?  I did a search for "stained glass" and got nothing that applied to my problem.
Thu, May 24, 2012 at 10:49:31 AM | Transparency problem. Inserting tif's for decals, the transparent background...
4 Stars: 205 Votes
Search for "PNG"
http://www.revitcity.com/forums.php?action=viewthread&thread_id=20199
http://www.revitcity.com/forums.php?action=viewthread&thread_id=17655
Thu, May 24, 2012 at 11:30:54 AM | Transparency problem. Inserting tif's for decals, the transparent background...
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I have a png file where the background has been changed to transparent.  I have inserted it as a decal onto a gym floor.  When I render, the transparent background is lost and the image renders with the color background that was made transparent in the png.  The png file inserts into Word just fine and the transparent background stays transparent.  Not so in Revit when rendered.
This is not the "MentalRay won't let you insert background images in rendering like Accurender did" problem.  It may be related, but the two links you gave me don't address my situation.
Thu, May 24, 2012 at 12:34:22 PM | Transparency problem. Inserting tif's for decals, the transparent background...
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
My reseller tech guy says that Mental Ray will not support transparencies at all.  He gave me a work around.  He said to create a negative image of the art that I want inserted.  Insert the original image in the decal.  Go to the bottom of the decal properties page and click on cutout.  Select the negative image for the cutout.  When you render that decal, the background in the image has been cut away.  It works.
Thu, May 24, 2012 at 12:47:44 PM | Transparency problem. Inserting tif's for decals, the transparent background...
Thanks for the useful post.
decals
Fri, Dec 19, 2008 at 8:59:58 AM
Glass transparency when plotting
Mon, Jul 18, 2005 at 1:07:06 PM
white background on decals
Thu, Aug 19, 2010 at 9:42:15 AM
Windows Transparency
Sun, May 21, 2006 at 11:43:15 PM
PNG- TRANSPARENCY- COLOR SCHEME
Sun, Sep 30, 2018 at 10:09:50 PM
Page generation time: 1.6614
