Forums >> General Discussion >> Revit Project Management >> length in beam tag
Wed, May 23, 2012 at 6:08:21 AM | length in beam tag
arc10life
I would like to add the length of all my beams to beam tag.
However, when i try to add it when editing the label for the tag, there is no Length option available?
However on all my beams, under the dimensions section the length is shown! Thanks for any help!
Amir
Wed, May 23, 2012 at 7:27:00 AM | length in beam tag
There are only a few special tags that read project values.  For instance, room tags will read area and volume, ceiling tags will report height but for the most part, you can not create tags to read project values.
Fri, May 25, 2012 at 11:45:28 PM | length in beam tag
arc10life
thanks
Sat, May 26, 2012 at 12:25:40 AM | length in beam tag
arc10life
you may be able to do a shared Reporting parameter, add that to the beam that reports the beam length,
then add the parameter into the beam tag.
http://www.revitforum.org/structure-general-questions/8443-tagging-beam-length.html
Creating a Beam Family Where Each Type has a Determined Length
Wed, Aug 31, 2016 at 11:55:27 AM
11
Beam System Tag
Fri, Aug 14, 2009 at 3:09:33 AM
Beam tag on roatated beam
Fri, Feb 22, 2019 at 3:21:01 PM
Beam System tag
Fri, Nov 3, 2017 at 3:53:13 PM
Shear Wall Length
Tue, May 24, 2011 at 5:00:45 PM
Page generation time: 1.7461
