Forums >> Revit Building >> Technical Support >> Cutting with Voids outside of families
Wed, May 23, 2012 at 5:50:49 AM | Cutting with Voids outside of families
JRPcad
Hi all,
Just wondering if at all it is possible to use voids to cut already created families?
Basically I'm using the standard cladding family (found in the the standard library), This works by arraying a number of similar pices to create the internal and external look. I'm using this cladding in a number of ways that require a given profile, rather than just being rectangular. The ideal for me to have done what I needed to do would be to just create voids in my main model and use them to cut the cladding as and where i need (As if i were using the cladding as a wall object). however because they are a family voids won't touch them, unless I create nested voids within the family. I could do this but it's very hard to guage where the voids should be when the family consists of only one small piece of the cladding.
Has anyone found a way of using voids to cut families, without creating a nested void in the family?
For Architectural Services visit www.jrpcad.co.uk
Wed, May 23, 2012 at 7:22:05 AM | Cutting with Voids outside of families
I use face hosted voids to cut other families.
Wed, May 23, 2012 at 7:53:29 AM | Cutting with Voids outside of families
JRPcad
Hub you're a genius, It worked a treat Winking
voids not cutting
Wed, Jul 8, 2015 at 10:14:50 AM
**EMERGENCY** Please help! Nested countertop family voids showing in model
Wed, Dec 31, 2025 at 7:12:02 AM
Voids in Section
Mon, Oct 10, 2005 at 9:55:51 AM
Voids Through Many elements
Tue, Aug 11, 2009 at 2:32:33 AM
Cutting roof frames
Wed, Dec 19, 2012 at 9:35:30 AM
Page generation time: 0.9440
