27 Users Online (25 Members):
Forums >> General Discussion >> Revit Project Management >> Hide all objects of same family
8 Posts No Rating |
Hi everyone
I am an architect and linked mep to my revit file
we have "exhaust fans" and "Packaged Water Chillers"
now,I want to hide all "exhaust fan" in roof plan,
so
-if I unmark the mechanical equipment in V/G , all of them...hide
-I can not say to mep team to specify a workset for "exhaust fans"
-and it is impossible to select one by one with tab and hide them
Thanks to show me the best way
If they are all the same family, right click select one and pick - select all instances - visible in view, then hide them.
8 Posts No Rating |
thanks for your attention but: "select all instances" is inactive for linked file I want to hide a family of linked file >>>>>> MEP in architecture project
8 Posts No Rating |
While the pull down for the filter won't show the linked model's families,
you can type in the name manually and it will work. (I just tested it with 2012, worked just fine)
by MPwuzhere
Moderator of revitforum
http://www.revitforum.org/architecture-general-revit-questions/8441-hide-all-objects-same-family-2.html
Hide/ Isolate objects question |
Tue, Mar 18, 2008 at 6:35:09 AM
Why symbolic lines and hide objects?? |
Tue, Nov 18, 2008 at 12:42:24 PM
Hide/isolate in view versus in print |
Sun, Mar 22, 2009 at 4:01:20 PM
Using underlay to show only exterior objects |
Wed, Dec 3, 2014 at 12:11:02 PM
Hide Objects between sheet and view |
Fri, Jul 23, 2010 at 7:23:48 AM
