6 Users Online (4 Members):
Forums >> Revit Building >> Technical Support >> Rev 13 deleting un-used levels
1 Posts No Rating |
Hi, I am quite new to Revit using Revit 13 for structural modelling. In my current project views being used are shown in project browser. When I go to for example change reference level of a beam the drop down menu still shows a very long list of previously created levels that I have since deleted from the views.
Is there any way to edit this list?
Thanks
Lee.
You re trying to delete levels from your project? In you project browser select the level, right click and delete. Or if you go to an elevation you can select the level and delete it and it will delete the level from your project also.
Deleting from the project browser will only delete the view, the level will still be there.
" if you go to an elevation you can select the level and delete it and it will delete the level from your project also."
Yes that is why I gave the other option as well, I was not sure exactly what he was trying to accomplish.
Edited on: Tue, May 22, 2012 at 11:14:43 AM
Replacing levels with ref planes or deleting excess levels |
Thu, Apr 17, 2008 at 11:10:37 AM
Deleting Levels without deleting associated walls |
Thu, Jul 30, 2015 at 2:43:47 PM
deleting levels without deleting associated objects on it. |
Thu, Aug 1, 2013 at 6:20:35 AM
RAC 2010 - Revision Block Disappears on Rev. 2 |
Thu, Jul 8, 2010 at 11:16:36 AM
Rev 2009 Importing Structural Dwgs into Arch dwg |
Mon, Jul 25, 2011 at 7:39:15 AM
