Forums >> Revit Structure >> Technical Support >> a New type of a family "Tag", help!
Tue, May 22, 2012 at 3:19:44 AM | a New type of a family "Tag", help!
Kautar
See attached picture!
I am trying to make the lines editable with "breaking-points". I succeed to make the two end points with template "Metric Detail Component line based". But don’t understand how to create more of this Reference lines..? The idea should be to create four of these lines to get the lines I want…
The other thing I having problem with is the “Tag” text. I actually prefer to have a simple text that I in project can change instantly. Thou, I realize that one can’t make Text-labels in the template that I was using for making my lines. I am trying to load in a other family with text-labels, don’t work…
Any ideas..?
(I use Revit Structure 2012)
Thu, May 24, 2012 at 7:47:46 AM | a New type of a family "Tag", help!
Cadman202
Kautar, i was able to make something like what you had in your picture with the "Generic Annotation.rft". You can add a label to it. then for the lines you needed. you can just add some leaders to it. let me know if that helps you out.
Fri, May 25, 2012 at 8:40:29 AM | a New type of a family "Tag", help!
Kautar
Yes, thx! It helped alot. =) now I can do it as you say with leaders.
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Tag Types
Thu, Mar 11, 2010 at 6:01:02 PM
casework tag: loaded? unloaded?
Sun, Aug 3, 2008 at 6:00:38 AM
callouts with "typ" label?
Mon, Sep 15, 2008 at 1:44:41 PM
Page generation time: 2.3013
