Forums >> Revit Building >> Technical Support >> Historical Building from CAD to REVIT
Fri, May 18, 2012 at 6:02:42 AM | Historical Building from CAD to REVIT
jackdaniels24
jackdaniels24 Avatar
Hi,
I've imported a CAD dwg 2D floor plan into REVIT(2012) and I'm looking for a way of creating the walls for this particular historic building. I know I could pick lines if the walls were straight and of even thickness but I'd like to keep the 'as surveyed' details of the walls. Ideally, I'd like to 'pull up' the walls like you would in sketchup. Has anyone any ideas for this? I've attached a PDF of said GF plan showing external walls.
Regards ... J.D.
Fri, May 18, 2012 at 7:03:06 AM | Historical Building from CAD to REVIT
The interesting thing about existing building surveys is that they are accurate only at the point of the measurement.  Since this is a 3D world, they are most likely not correct above and below that point.  So why think that simply extruding these lines up is an accurate representation?  However, you can extrude all of these as in-place walls ... but you will have many, many problems doing this. Especially at the top conditions.
The traditional way of representing existing buildings is to use straight or curved walls as appropriate that average the existing conditions.  I believe this to be a far easier approach, and overall, maybe just as accurate.  When people use a 3D point cloud survey, the software will find a face that represents most of the 3D points and use that.
Fri, May 18, 2012 at 9:54:37 AM | Historical Building from CAD to REVIT
coreed
coreed Avatar
4 Stars: 16 Votes
if you want to pull the walls up like you would in SketchUp, use a in-place Mass Extrusion or use the Conceptual Editor.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Historical Bar Joist Families
Wed, May 25, 2022 at 5:32:57 AM
Historical Wide Flange sizes
Fri, Aug 7, 2009 at 12:22:35 PM
Quickest/Simplest way to make historical cornice
Tue, Oct 4, 2011 at 9:06:09 PM
Revit export to CAD
Mon, Oct 4, 2010 at 4:43:05 PM
cad symols into revit for presentation
Tue, Nov 11, 2014 at 6:15:03 AM
Page generation time: 1.6572
