Forums >> Revit Building >> Technical Support >> Restore Beams to Beam System
Thu, May 17, 2012 at 3:58:59 PM | Restore Beams to Beam System
leothelionator
In Revit Architecture 2012, is there a way to restore physical beams to the beam system grid once they've been deleted?  I understand that beams are created when a beam system is created, but once individual beams are deleted I can't find a way to get them back even though the ghost of the beam system (the blue dashed lines) is still present.
Mon, May 28, 2012 at 11:17:01 AM | Restore Beams to Beam System
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Select the beam system > Edit sketch > Restore system
Planta1 Revit Online Consulting | info@planta1.com
Tue, May 29, 2012 at 9:19:42 AM | Restore Beams to Beam System
leothelionator
Thanks, that's just what I was looking for.
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:20 PM
beam system
Thu, Oct 15, 2015 at 7:32:17 AM
RAC2009 Beam system
Tue, Jul 22, 2008 at 11:16:14 AM
Beam System Tags
Wed, Feb 27, 2013 at 12:55:27 AM
Beam system justification
Fri, Jan 27, 2012 at 3:47:56 PM
Page generation time: 2.8827
