Forums >> Revit Systems >> Technical Support >> HVAC diffuser question
Wed, May 16, 2012 at 8:36:13 PM | HVAC diffuser question
tarag
We are all new with revit mep 2012 and this is what happened.  Several (lots) diffusers were placed by a drafter and they are the wrong size and type (family), is it possible to replace them globally, kind of like redefining a block in autocad?  thanks for any help.
Thu, May 17, 2012 at 9:16:14 AM | HVAC diffuser question
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can select all of the diffusers by clicking on the object, right click, select all instances in project, then change the type in the type properties.
HVAC Diffuser will not print
Wed, Jul 23, 2008 at 12:48:12 PM
2D diffuser transparency
Wed, Jan 8, 2014 at 8:31:36 AM
12
REVIT MEP, Diffuser Airlfow Parameter isssue
Mon, Jun 21, 2010 at 1:46:22 PM
Linear Air Diffuser
Sat, Jun 11, 2016 at 12:58:53 AM
Diffuser
Tue, May 29, 2012 at 8:24:46 PM
Page generation time: 0.2848
