Forums >> Revit Building >> Technical Support >> Offsetting a wall created on a mass
Tue, May 15, 2012 at 3:27:45 PM | Offsetting a wall created on a mass
Teeni
3 Stars: 1 Votes
I know the usual way to use layered walls is adding the layers in wall types. I am trying to build the individual wall layers to better mimic real world construction. I am working with a complex building so a mass is needed to create the wall slopes. Is there any way to offset walls from the mass face? I want to drive them parametricly, but so far I can only manually pull the walls off the face.
Heres the model I have been playing with. Any thoughts or suggestions will be helpful!
Edited on: Tue, May 15, 2012 at 3:37:23 PM
Wed, May 16, 2012 at 8:03:57 AM | Offsetting a wall created on a mass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't believe that you will be able to offset your slopped walls from your mass.  Why are you trying to offset them from the mass anyway instead of just drawing them where you want them?  However when you change a parameter of your mass you can align the wall back to the changed parameter by clicking the face of the mass you moved and the face of the wall you want to attach to the mass.
Wed, May 16, 2012 at 12:04:30 PM | Offsetting a wall created on a mass
Teeni
3 Stars: 1 Votes
I was kind of hoping for a quicker way to update the faces. The idea of the model is that its a working section where I can change change the mass to reflect any part of the building. I was thinking that if I could offset the walls using a paramater, updating the faces would not require me to manually reset the offsets.
Wed, May 16, 2012 at 12:18:20 PM | Offsetting a wall created on a mass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can use the Update to Face tool. This should get the result I think you are looking for
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/2427-Analyze_2427/2558-Massing_2558/2601-Creating2601/2610-Updating2610#GUID-5570AABE-34F0-45B7-B42A-EF3E99309EA5
Wed, May 16, 2012 at 1:21:27 PM | Offsetting a wall created on a mass
Teeni
3 Stars: 1 Votes
Update to face works for changing the shape and slope of the wall layers. However, the wall snaps back to the face to which I am updating it and I have to manually create the offset again.
shaft through a wall created from a mass
Tue, Mar 24, 2009 at 2:27:05 PM
How do you hide mass created in adaptive componnents?
Tue, Jun 26, 2018 at 4:43:28 AM
Mass, radial wall by face, opening(void) problem!
Mon, Nov 11, 2013 at 12:51:10 PM
Mass visibility
Thu, Sep 6, 2012 at 10:41:23 AM
wall by face not being cut by void in mass
Wed, Jul 17, 2013 at 3:33:06 PM
Page generation time: 1.2632
