Forums >> Revit Building >> Technical Support >> Default fill region
Tue, May 15, 2012 at 11:30:55 AM | Default fill region
Whachumacallit
I am new to this posting so sorry if I post this in the wrong place, but I would like to change my default fill region pattern from a honeycomb pattern to just plain Solid White. I have asked regular users and they are stumped. There does not seem to be a simple check box or other readily visible location to set the default pattern. Any help appreciated. Thanks.
Tue, May 15, 2012 at 11:42:11 AM | Default fill region
Whachumacallit
I am new to this posting so sorry if I post this in the wrong place, but I would like to change my default fill region pattern from a honeycomb pattern to just plain Solid White. I have asked regular users and they are stumped. There does not seem to be a simple check box or other readily visible location to set the default pattern. Any help appreciated. Thanks. Using Revit 2012.
Tue, May 15, 2012 at 11:55:19 AM | Default fill region
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't believe you can pick the default fill region.  When you use a fill region once Revit will remember your last used filled region patter and use that as the default for the next filled region.
Tue, May 15, 2012 at 12:11:29 PM | Default fill region
Whachumacallit
Thanks for the reply...not quite right....meantime, somebody at the office here figured out that you have to actually open the central file and do a filled reqion with the desired pattern, save and close. Otherwise, what you stated does not actually happen, it keep reverting to the original fill region, in my case honeycomb. If I am wrong, I apologize. We no longer have Scott Womack here in the office to ask these questions. Thanks again.
Tue, May 15, 2012 at 12:22:00 PM | Default fill region
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I am currently working in a local file which is attached to a central file (of course), and when I do a filled region of grout the next time I do a filled region it defaults to grout.. If I do one of rigid insulation the next time I do a region it defaults to rigid insulation.  I just realized that you are running 2012 and I just tried it there and you are correct.  I am running 2013 so it appears that they fixed that little problem in 2013.
Tue, May 15, 2012 at 12:25:54 PM | Default fill region
Whachumacallit
THanks again for you help. I should really use a mask vs fill, as pointed out by a co-worker. Very much appreciated. No more help needed, Thanks.
Tue, Jun 2, 2015 at 9:11:01 PM | Default fill region
amara58
1 Stars: 1 Votes
If you are using fill from default patten, there are 2 ways to do the change. Just heightligthen the patten then:
  1. Go into properties and change into grayout.
  2. Right click the mouse > override graphics in view > by element > view- specific grahics > surface pattern > color [choose] > Pattern [solid fill]
How to change default filled region type
Mon, Feb 18, 2013 at 4:06:50 AM
fill pattern and line style
Thu, May 5, 2005 at 6:25:07 PM
How to I have a fill region or masking region and have my CAD import over it?
Tue, Oct 20, 2015 at 1:09:06 PM
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Unable to select the fill region
Mon, Aug 13, 2012 at 3:51:58 PM
Page generation time: 1.2955
