Forums >> Community >> The Studio >> creating screens
Tue, Dec 27, 2005 at 4:27:48 PM | creating screens
hammer87
hammer87 Avatar
3 Stars: 4 Votes
i was worndeing if howtocrayea sreen in revit for a proch
Wed, Dec 28, 2005 at 6:04:12 PM | RE: creating screens
meelio
2 Stars: 3 Votes
Just use the wall tool, using an appropriate material setting. Or same material using the massing tools if you're concerned about wall scheduling in the future. Either way is easy.
Thu, Dec 29, 2005 at 11:30:28 AM | RE: creating screens
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ok well so i could se this to create a screened in porch? also what material would be an ideal choice and would i have to do this in a wal profile?
Fri, Dec 30, 2005 at 11:00:29 PM | RE: creating screens
meelio
2 Stars: 3 Votes
A screened in porch would probably be best simply with the wall tool. If you don't want the wall to reach a second storey level, set a height (top offset) from your bottom offset in the wall's parameters. (This can be done before or after you create the wall.) Material - it depends how you want it to look! Brick, rendered, timber palings, whatever! Have a 'flick' through your materials list and see what looks good to you.
Mon, Jan 2, 2006 at 10:57:27 AM | RE: creating screens
hammer87
hammer87 Avatar
3 Stars: 4 Votes
so if i did the wall, how owuld i make it so that it looks screened in?
Mon, Jan 2, 2006 at 3:44:03 PM | RE: creating screens
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Personally i'd either use a railing or a curtain wall to achieve this.
Mon, Jan 2, 2006 at 4:02:54 PM | RE: creating screens
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
In answer to your question regarding the material used for the screen, I suggest you take my tutorial about transparency mapping. http://www.revitcity.com/tutorials/transparency_mapping/tutorial.php
Hiroshi Jacobs
Tue, Jan 3, 2006 at 12:21:28 PM | RE:
hammer87
hammer87 Avatar
3 Stars: 4 Votes
Quoting Mr Spot - 2006-01-02 15:44:03
"Personally i'd either use a railing or a curtain wall to achieve this."
would i just make the railing tall?
Tue, Jan 3, 2006 at 4:43:14 PM | RE: creating screens
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Make it as big as it needs to be. If it needs to attach to things or will vary in height use a curtain wall...
Tue, Jan 3, 2006 at 8:07:22 PM | RE: creating screens
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ok i think i understand how this is supposed to work..can iput doors on a curtain wall?
Wed, Jan 4, 2006 at 1:31:52 AM | RE: creating screens
#11
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Certainly can. They just work differently you have to swap the panel out for a specially created curtain wall door or swap out a panel for a wall then place a normal door... Do a search on some of the curtain wall threads, they should give you a good idea.
Wed, Jan 4, 2006 at 7:26:03 AM | RE: creating screens
#12
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ok thanks i ll try. to me it sounds difficult doing curtaun walls. btw, which one would you recremend, store front, or the other two types?
Sun, Jan 8, 2006 at 9:42:21 PM | RE: creating screens
#13
jobcaptain
jobcaptain Avatar
1 Stars: 2 Votes
Here's a screened porch I've been designing. I used a Screen pattern material file I found on revitcity...same with the 3-tab shingle pattern on the roof in this view. I used a curtain wall, solid & screened panels, a door is placed in the wall (still designing the door family from the mfr catalog). As was previously stated I adjusted the transparency setting so we can view thru the screen and also conduct sun/shadow studies with some tree options also contained in a Revit design options. In Elevation Views, the screen is not transparent (acts like window glass in elevation) Actually, I have 3 Revit design options for this space...one is this screen option vs a full insulated wall vs completely open but covered patio space. Cheers. Revit Blog: www.taylor-tech.com/danielhughes
LinkedIn Profile:
  • http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com
Sun, Jan 8, 2006 at 10:33:37 PM | RE: creating screens
#14
eldados
eldados Avatar
4.5 Stars: 8 Votes
The best solution imho is like Mr spot said, use railing! easy to use, you can define and change profiles and heights. you can still insert a door, just create a clear wall insert the door and set the lenght of the door to the opening size, you won't see it. OR, if you feel like trying something a little harder, try Mr. Spot tutorial about nested array families. you can create a fully parametric screen family. Smile
Integrator
KarelCAD
Mon, Jan 9, 2006 at 1:09:29 PM | RE: creating screens
#15
hammer87
hammer87 Avatar
3 Stars: 4 Votes
thanks, i used Mr. Spots idea of using railings. and im having trouble downloading pattern
Interior Doors / Screens
Thu, Sep 13, 2007 at 9:09:22 AM
Dual Screens with Revit on PC and iPad
Mon, Jul 14, 2014 at 3:59:51 PM
What's the best way to make screens in Revit Architecture 2012?
Wed, Feb 29, 2012 at 3:07:45 PM
Graphics Card
Fri, Aug 5, 2011 at 10:37:58 AM
Stretching to 2 screens
Thu, Apr 23, 2020 at 5:04:16 PM
Page generation time: 0.9024
